Greg Rozar AKA- CubDieselFan
Old 05-13-2013, 12:50 AM
Cjbdvm04 Cjbdvm04 is offline
Default How long for spray can to cure
I just used a bunch of aerosols to paint my 127 (engine/frame parts/etc). How long does aerosol take to cure so that it isn't susceptible to gas or other solvents?
Old 05-13-2013, 01:21 AM
Almost a year.... no joke. Ive had things that were painted with rattle cans for months... spilled gas on them and they peeled. Even had pretty decent automotive paint do the same thing.
Old 05-13-2013, 03:22 AM
cubby102's Avatar
cubby102 cubby102 is offline
Just be really really carefull.
1872 - 60"haban 54" power angle haban blade
'63 Original - restoration project
582 -tiller
147 - leaf duty with bagger.
1811 - Ditch mower
800 - have it just cuz its a 800
Old 05-13-2013, 06:39 AM
Heat helps, just sneak the parts in the oven after the wife pulls out the cookies!!
The heat really cures the paint. I have even used a black plastic tent outside when the sun was real intense.
Maybe I need to move to Arizona!!
Pretty much the paint will be less effected by gas when the volatiles are driven out of the paint.
Time or heat, your choice.
Old 05-13-2013, 07:36 AM
cubby102's Avatar
watch out using the heat with the fuel tank also...not because of fumes but because the solder holding the tank together has a fairly low melting point..
582 -tiller
1811 - Ditch mower
Old 05-13-2013, 08:41 PM
cubfixer's Avatar
cubfixer cubfixer is offline
Also, make sure you use a good quality primer. I use rustoleum (brown) or the grey automotive kind. If you just use the color coat it is much more susceptible to gas lifting the paint.
John
Old 06-07-2013, 10:59 PM
johncub7172's Avatar
I really let the painted parts dry and cure. The Cub Cadet Yellow can seem to take up to 3 weeks, depending on weather conditions. I watch what those are going to be before I'm painting. In my case, most all of what I got painted yellow will be long cured by the time I get around to re-assembling this 72 re-power/refurb!
Old 06-07-2013, 11:04 PM
I painted this a few days ago.
Left in the sun on a dark surface, at 88 degrees, the next morning it was rock hard!!
Old 06-08-2013, 06:46 AM
nikster's Avatar
nikster nikster is offline
I'm not a paint expert sooooooooooo? But............
Seems that no matter what that paint always bubbles or washs away a bit. A friend of mine told me to scuff of the paint a bit after curing, & buy some clear - cote (spray can) from auto store & give it 3 good coats. He said that might work?
NIK,
Old 06-08-2013, 08:46 AM
Thumbs up
Right you are! I will paint in the shop, and then hang out in a hot sun to dry any chance I get! I had also painted with the Cub Cadet Yellow under a Dayton heater back at the shop during winter months. The paint will flash resulting in a terrific bond. Seems to speed up the curing and drying process significantly. I had painted many parts as I could, and wow! did those turn out better than factory!
