Greg Rozar AKA- CubDieselFan
Old 12-06-2021, 07:00 AM
XT1 Guy XT1 Guy is offline
Default XT1-42 questions
After 18 years of faithful (even though in retrospect abused) service the JD 110 quit. The transaxle a K46 failed. I bought a surplus K57 but had to reverse the motor mount and basically failed. Now I needed another machine as grass was getting tall. Looked at JD and came to the conclusion that green paint must have gold in it as it was very expensive. Did more research, was really interested in at least a k 46 transaxle in a machine in my price range. Did some research, went to the cub cadet site and the specs had an xt1 had a k 46. Great. Tried to find one locally, could not. Found one at Home Depot about 60 miles away. They delivered it no charge. But looking at the tag it had a TL200 trans. But it had a Kohler engine, not the Chinese made. Felt good about the engine, a little upset about the tranny. Questions:
Did CC change the tranny and engine between 2020 and 2021?
How good/bad is the TL200
I've heard that an oil change at 50 hrs with 5/50 synthetic is the way to keep a k 46 going strong, same with TL200
I LOVE it. seat is great, turning radius is unbelievable, Can't figure out the cruise control though.
Old 12-10-2021, 07:20 AM
Billy-O's Avatar
Billy-O Billy-O is online now
Tractor Data dot com is a good goto website for many of the older garden tractors. Consider yourself lucky that TD has some information on newer lawn tractors. Compare the two links and you'll note the differences in transmissions. It seems there was a transmission and a engine change from 2015-2019 model years to 2020-2021 model years.
https://www.tractordata.com/lawn-tra...-xt1-lt42.html
As for engines in 2015-2019 models: http://www.kohlerengines.com/engines...ourage%20SV541
And engines in 2020-2022 models: https://kohlerpower.com/en/engines/product/ks540
I Google the engines from the Tractor Data site in reponse to your other post about which engine has EFI...I'm seeing very little about whether the engines are carburated or fuel injected however I may have missed that in a quick glance thru the links.
Plow blade
#2 Cart
QA36 snowthower
Old 12-10-2021, 07:45 PM
Ozcubowner's Avatar
Ozcubowner Ozcubowner is offline
A mate just bought an XT1 and it has a V-twin Kawasaki , 24hp
As to 50 hours for first oil change no way , 5 to 10 hours at most
Oz
Old 12-10-2021, 08:13 PM
Farmall450's Avatar
CC is putting whatever parts they can get on them now.
For the first 6 years of the XT1 the "base" was always Kohler command* series, 1 lunger and a Tuff Torq K46. Then 2020 brought the dial-throttle China motor -- this year is just whatever. Getting 2022 models in now, but haven't looked into the 42 yet.
Edit: cruise is easy, push right foot to approximate speed, pull up toggle in middle to lock in. There are only like 6 positions.
Old 12-11-2021, 10:28 PM
Ozcubowner's Avatar
Apparently out here we get a choice of 4 XT1 , cheapest has China motor , next up has a Kohler then the XT1 LX 42 has a Kawasaki then a 4WD model
The XT1 LX 42 $6000.00 Aud
Oz
Old 12-11-2021, 10:57 PM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
When i worked for the farm store i think we had 6 different xt1 models with different engine, trans and deck combos.
I never did understand why they didn't have a more clear way to identify them. Only way to know for sure what you have is look under the seat at the actual model number.
JD x475
Farmall450's Avatar
Oz
Yes, I've always been able to special order the Kawi, but often just stock an XT2 42 Kohler (twin 7000 series vs the one lung command) and sell that instead.
Old 01-26-2022, 02:27 PM
Thanks, good web site. I guess shame on me for not digging deep enough.
Old 01-26-2022, 02:30 PM
Thank you everybody. Enlightens me. Guess I should be glad it has a Kohler engine.
Anyway, when the K 57 gets out of the shop I think I'll put it on it. The toughest XT1 42 in town. (If it fits)
