Went out todday and draged mine down to the garage and put it
under the tractor "149" the only thing I can see wrong is the 2 uprights were the connecting rod goes through need to be cut off and longer ones welded on and at an angle to clear the front axle if it were to pivot, the way it is right now on mine it would be riding on the bottom of the axle. But this would work and there is plenty of room to swing the blade either L. or R. . Now here is one more question for everyone to ponder Would you use chains or a solid bar to do the lifting ?? I don't want to mess up anything on the lift arms or pins. Like I said this sucker is a heavy blade and the weight would be a plus on keeping it down. I don't think this was CC implement but could work fine with a lil reworking. DING |
The blade in Duncan10072 picture looks like one from a Simplicity/Allis Chalmer garden tractor.
I talked with the guy that I bought the 125 from and he told me that he got it when he bought the tractor new along with the mower deck. He was the original owner, he said it had been 25 years since it was on and he couldn't remember how, but he did have it on when he was leveling dirt around his house. He said it was possible that a piece or two was missing, he just couldn't remember. I will try to see if I can try and get it under the 125 soon and let you all know what I find out. Thanks for all your help
Rod |
Go to one of these sites:
http://bsintek.basco.com/BriggsDocum...E3CSl5kbp796Dq http://www.simpletractors.com/simpli...ader_blade.htm Does this blade look familar? |
That's it Merk right on the money
Thanks Merk, you are right on the money again. Thanks for the info, I guess that a guys memory goes bad after a while. He must have had a Simplicity at some time and just forgot when he told me he got it with the CC125. I am still going to see if I can get it under one of my cubs to see if it will work. Thanks again for the info everyone.
Rod |
Due to the color being yellow, it is probably the Allis-Chalmers version.
http://www.simpletractors.com/attach...ader_blade.htm http://www.simpletractors.com/attach...ader_specs.htm Neat and simple. I may try to find a blade and make one out of an old mule drive to mount to a Cub Cadet.
I like pie |
Nice weight system on that grader blade, eh?
It's so nice out.....I think I will leave it out! |
that would be a neat looking tractor if it had some foot boards or at least larger ones.
Duncan , I tried the mule drive mounting bracket and it will work, but the PO had a chain connected to a bracket bolted to the big bolt that mounts the blade to the swivel and mounting bracket to lift it. I made another bracket for the other side and connected the chains to the lift mech. under the 149 and it works fine as long as the blade is straight, but if you try to angle the blade it tilts the blade and carriage so the only thing I can do is connect the chains ahead of the swivel point to lift. Haven't had time to do or try this yet. The only other thing I did notice was when playing around with it is if you try to get into hard dirt or on a mound the blade will rise and is really close to the bottom of the tractor. That angle bracket on the top of the frame is really close to the steering drag link I think this will get reworked to the bottom side. I think it will be fine in gravel or loose dirt but its going to take some weight on the blade to make it cut in hard dirt.
Ding |
Thread Tools | |
Display Modes | |
