Greg Rozar AKA- CubDieselFan
Old 03-20-2009, 06:31 AM
rfrank's Avatar
rfrank rfrank is offline
Default Green or White Story
Hello all, nice to see a fresh start to a great website. Ive got a 149 that was given to me, Its in really good shape. . .really. My brother bought two garden tractors at his local citywide garage sale for 300.00 one was green and the other was yellow and white. This past winter he asked me if I might want the yellow and white one as he just wanted the green one. Well we grew up on a farm and my first few jobs were with farmers tilling fields. Ive driven bigger deeres, IH(1066, 1466), Chalmers tractors. WE grew up with deere but I always liked the international. I always liked playing with the TA(torque amplifier). So when my brother asked I hesitated in disbelief. So now I own a oct 1973 149 with a 42in deck. My brother is green(pun) with envy as he cant get his green thing running(212).
Question Im fabricating a rear lift arm and wondered if anyone could give me the diameter of the rod that holds the lift arm to the frame. I need to make one and want it as close to original as possible, just in case I run across one(lift arm) cheap. Thanks for your input
- Bob
Old 03-20-2009, 07:19 AM
Bob:
Great story. Glad to see you end up with the 149.
Is this what you are looking for....
Roland Bedell
Buy: Made in the USA
Old 03-20-2009, 07:24 AM
dyt4000's Avatar
dyt4000 dyt4000 is offline
RB,
I think he might be talking about this one...#1 in the photo...
IH-547701-R1
Shaft, Lift Lever
Co-Founder
You only need two things in life...duct tape and WD-40
If it's stuck and needs loosening, use the WD-40.
If it's loose and it's suppose to be stuck, use the duct tape.
Old 03-20-2009, 07:47 AM
rfrank's Avatar
Yes the lift lever diameter #1 in the picture. Thanks for the info.
Old 03-20-2009, 08:31 AM
Sorry...I misunderstood
The dimensions of that Lift Lever Shaft is:
Diameter: 5/8"
Length: 12"
Roland Bedell
Old 03-21-2009, 06:58 AM
rfrank's Avatar
Thank you, So looking at the inside diameter of .625 and the rod being the same then the rod is designed too be a zero tolerance fit? Then I would assume that the lift arm rotates with the rod in the bushing on each side of the lift arm where they are tack welded to the frame? Thanks for your help
Old 03-21-2009, 07:05 AM
The Lift Lever Shaft is a loose fit to the Lift Lever Arm.
Roland Bedell
Old 03-21-2009, 07:15 AM
rfrank's Avatar
OK, great thanks that makes more sense for ease of operation assemble and disassemble. Now Im thinking
Old 03-21-2009, 09:00 AM
jfinney's Avatar
jfinney jfinney is offline
Glad you ended up with the 149...I'd love to have a 149. My next CC will have hydraulic lift on it. Sure makes it nice with plowing snow, and plowing/tilling the garden. Thanks for sharing the story. Jason
