Greg Rozar AKA- CubDieselFan
Old 03-29-2018, 08:37 AM
Originally Posted by sorner View Post
This is not a hacksaw and grinder job...
Neither is rebuilding a cylinder.
Hey, listen I don't want to beat this to death... but when I was a kid I had a 3 wheeler that got so wore out it wouldn't hardly start. I took the head off and found a burnt valve. I wasn't going to spend the money on new valves, or a valve job... so, I chucked the valves up in a drill press and used a hand file to "true them up". Did it work... oh yeah. Put them back in and it would actually start. Rode it several more years like that. Point is, just because you can do something, doesn't mean it's the right thing to do.
Or is that a machine shop replica type deal?
No, a machine shop cannot make that piece. The surface is machine flat and lapped, then case hardened so the bearing can ride on it. It's a buy thing.
Edit: looks like part number 1679026SM and it’s about $166 if it’s available.
Check around.
Your choices are new, used or find a different source for the new part. Or put it back together and see how long it lasts. Looks pretty rough from here, but the pic you took isn't great..... I can't see how bad it is very well.
Old 03-29-2018, 08:48 AM
sorner's Avatar
sorner sorner is offline
Check around.
About that cylinder... Let it be...
About the steering unit, the surface is pretty rough and pitted where the backup ring sits. I'm not going to bother putting that back together, it won't last and I'm not wasting a seal kit on it. I have two of these to rebuild. My plan was to rebuild both and sell one. It's not worth it to me to spend a lot of money to repair this one since it is the extra one. The other one is on my tractor currently, I'm hoping when I get inside it that one it's not chewed up like this also, because that's the one I'm using. It's not leaking bad, but a drip here and there, and it drips on my deck and it's annoying because the dirt sticks to the residue. This one I'm working on now was like a hydro fluid geyser in the tractor it came from.
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower
IH Cub Original with deck
#2 cart
GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck
Old 03-29-2018, 09:02 AM
I doubt that happens......
Like I said, it looked pretty rough from the pic. But, there you go. Sounds like it was shot. Keep it around, or sell it as a parts valve. What's the rest look like? How's the valve rotor? Looks like that thing either got water in it from the top, or had crap in the fluid. Whole thing may be shot. Either way, I'd hang on to it until you get the other one rebuilt. Might need one of those Jesus springs.
Old 03-29-2018, 09:05 AM
sorner's Avatar
I agree it might have gotten water in it. I will keep it around for parts for the other one. The rest of it doesn’t look bad, following the manual. I will start a new thread on that project if need be. I was just wondering about that top piece for now.
#2 cart
Old 03-30-2018, 07:21 PM
sorner's Avatar
Here’s a better picture.
In other news, I got the other one out and cleaned it up and tore it down and it looked perfect inside. So new seals are in and it’s back together. That was pretty easy, I hope it works when I put it back together.
I will say this, the seal in the kit didn’t seem as thick as the old one. I hope that doesn’t matter.
#2 cart
Old 04-02-2018, 08:22 PM
taylorjm taylorjm is offline
Well I tore mine apart, put in new seals, put it back together. Was very careful to keep everything in the exact same alignment as it was. Had trouble getting the plate with the springs back in without them springing out, never to be found again. (I spent the $12 and ordered new springs just in case. Didn't end up needing them, whew) Nothing looked bad inside, all the seals looked good. I'm thinking it was the seal around the shaft that was leaking. The new seal kit had a little different looking seal around the shaft than the old one. It was actually a little smaller OD too, so that concerned me. I used the SK000011 seal kit for a steiner turf machine for $55 that someone here recommended. Had a couple seals left over that were dependent on exact model. So far, everything went back together and isn't leaking, and everything actually worked! Thanks for all the help!
Old 04-02-2018, 09:16 PM
sorner's Avatar
Same thing I found with the Steiner kit. So far no leaks here either.
#2 cart
Old 04-02-2018, 11:30 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
You owe Oak and I each $26.00 US
That's about the difference between ($52.00) the cub kit and the one I bought. Yeah yeah the way I see it, if it wasn't for Oak you wouldn't have known about the cheaper option but if it wasn't for me posting this thread at this time Oak wood have not had a reason to post the cheaper option.
1- 1200 in pieces
1- 1864 in pieces
Old 04-03-2018, 06:58 AM
sorner's Avatar
The checks in the mail!
#2 cart
Old 04-03-2018, 08:22 AM
I want $26 too. I didn't do anything but that's the world we live in today.
Pap's 100
Restored 108
1211 Dual Stick
1050
Thread Tools
Display Modes
