Greg Rozar AKA- CubDieselFan
Old 05-09-2018, 11:19 PM
sorner's Avatar
sorner sorner is offline
Man... what an oily gunk mess. I didn’t have any problem getting the engine pulled, seeing that 5 of the 6 bolts were only finger tight. This is not the first time I’ve found loose bolts there. Is this something that happens or am I just lucky.
I’m finally in to the flywheel side seal. I’m not completely convinced it’s the seal leaking. I’m thinking it looks more like the timing cover gasket, or the crankcase breather vent. The seal is pretty dry except for the oil soaked grass gunk you see in the pictures. Look at the left side when looking at it from the flywheel end it looks wetter. See photo evidence:
Last thing, I see in the manual that the condenser is under the points cover, mine is external and attached near the coil. Does this matter?
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower
IH Cub Original with deck
#2 cart
GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck
Old 05-09-2018, 11:23 PM
Regardless of how the seal looks it would be foolish not to replace it.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 05-09-2018, 11:25 PM
sorner's Avatar
I’m planning on it while I’m there. I just am trying to figure out where the leak is from. I don’t want to replace only the seal and still have a leak either.
#2 cart
Old 05-10-2018, 10:06 PM
sorner's Avatar
Default Possible Solution!
I think I have figured it out... I took the crankcase vent apart and found some dirt inside, and the gasket was cracked and brittle. I am pretty sure this dirt blocking the drain hole in the vent is why the PO blocked the tube and removed the vent tube from the intake because it was allowing oil to back up in there and get forced up the vent tube, and where the oil was leaking from. So, I am going to go over both valve covers and replace the gaskets, and replace the seals while I have it apart, and we will see what happens. Also, I noticed I am missing the tube that goes from the fan shroud up to the intake, is that an issue?
#2 cart
Old 05-11-2018, 06:24 AM
Sounds like you're getting the problem solved. I'm pretty sure you need that tube because the fan blows a good bit of air up into the air cleaner and without it the engine will run too rich. There was a guy on another forum that was missing that tube and he couldn't get it to run properly until he installed one.
Old 05-11-2018, 07:19 AM
Leadslingingdaddy's Avatar
they are also known to suck air through the split intake manifolds...Replace that gasket and use sealer.... It will surge if you have a leak....
Old 05-11-2018, 07:25 AM
The tube running to the air cleaner is there to supply cool air to the carb, without it the engine will be sucking in hot air from the top of the engine.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 05-11-2018, 08:26 AM
sorner's Avatar
$50+ for a new air intake tube... Hopefully I can find a decent used one...
#2 cart
Old 05-11-2018, 08:59 AM
The more I think about it the tube probably isn't a necessity, the Kohler KT and magnum's don't have them.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 05-11-2018, 09:30 AM
I may have one....
Thread Tools
Display Modes
