CC Speciaalties R. F. Houtz and Sons
Patton Acres IH Cub Cadet Parts
Greg Rozar AKA- CubDieselFan
Old 06-26-2017, 06:34 PM
Fetzfarm Fetzfarm is offline
Default 1250 not charging
Hello all,
My 1250 isn't charging. I looked in the technical bulletins section and where there used to be a picture of the solid state charging system test, there was a message from photo bucket saying 3rd party viewing had been temporarily disabled.
Either way, I gave it a shot. I'm really not good with engine electronics. I swapped out the ignition and the AMP meter, I had some extra parts laying around. Both AMP meters read at zero, they read just below zero if I turn on the lights or turn on the PTO. I checked the AC wire connections were they connect at the voltage regulator/rectifier with a multi meter and it was between 27 and 28 at WOT. I checked the DC from the voltage R/R to the battery and it was 11.63. There's a grounding wire between the bolt on the starter and the bolt going to the frame on the lower part of the grill. Those grounds are clean and solid. The ground to the battery is clean and solid.
The battery died when I fired it up to go back in the shed. I threw a trickle charger on it. The battery was purchased last year, it's the kind you use in the winter for blowing snow.
Thoughts?
Old 06-26-2017, 07:24 PM
First, the link in the Technical Library section has been fixed.
Replace the V/R.
Roland Bedell
Buy: Made in the USA
Old 06-26-2017, 09:19 PM
That's what I was guessing. Thank you Ronald!
Thread Tools
Display Modes
