Greg Rozar AKA- CubDieselFan
Old 06-19-2017, 10:49 PM
Sievert456 Sievert456 is offline
Default K321 balancing gears
I'm am currently rebuilding a k321 and was wondering if taking the balancing gears out would damage anything or potentially cause damage to anything?
Cub Cadet Original, Cub 147, Cub 125, 2 cub 1650’s, IH #1 Cart, tiller.
Old 06-19-2017, 11:47 PM
Nope remove them. I don't reinstall them in any motor.
Old 06-20-2017, 12:06 AM
Thank you J-Mech!
Old 06-20-2017, 10:05 PM
Another question. I have a 5 gallon bucket of flash solvent that I would like to put my block in but I don't want to take out my crank bearing as it is still good and run the risk of damaging it. Do you think it would be fine submerged for a day?
Old 06-20-2017, 11:01 PM
dodge trucker dodge trucker is offline
my bigger concern would be depositing all the crap that the solvent would dislodge, into the bearing..... simply soaking the bearing in the solvent wont hurt it as the splash of fresh oil as soon as the engine takes off upon its 1st start would take care of the lube issue, bearings are pretty "confined spaces" and would potentially hold a bunch of filings and such....
they aren't rocket science to remove, it would be a safer bet.
I see those gears in about 50% of the engines that I get into and I too leave them out if I find them. and once running again don't really notice that they made much if any difference in how smooth the engines run.
the bigger concern is if the bearings that support those balance gears fail (and they do) the remnants will take out the rest of your engine. and after all that work, I certainly would not want that.
Old 06-20-2017, 11:03 PM
Take the bearings out. Removing it isn't hard at all, and doesn't damage them.
