Greg Rozar AKA- CubDieselFan
Old 06-15-2017, 07:45 AM
Default Kwik way loader.
I thought I would start a new thread on this project, here's the pics you've all been asking for. Overall it's in great shape, the wear edge on the bucket looks like new so I doubt it's seen much abuse. I don't believe this loader was originally made for a Cub, the spool valve is on the wrong side( which I will be fixing ) and the subframe was welded onto the other tractor so I'm going to need to make some brackets. After closer inspection this morning it turns out that curl cylinders are in better shape than I thought, the rust you see is all the further in the cylinders go and when I pulled them out they're actually in decent shape.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 06-15-2017, 08:45 AM
Pic of a cylinder after 10 seconds with some emory cloth. The pits can barely be felt with a finger nail and I received a tip from another member on how to repair the pits to save from having the rods re-chromed so I will give that a try since I don't have that kind of coin right now.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 06-15-2017, 09:15 AM
farmall fred's Avatar
farmall fred farmall fred is offline
Tim, the spool valve on my Kwik-Way is on the left side. It was on a 1650 so that is why, opposite the hydro shifter lever. I have seen that loader set up either way. If I had it on a gear drive or a 1X8-9 tractor I would want it on the right side. If you need any pictures of the loader mounts let me know and I will send you some.
Good luck
Tom
Old 06-15-2017, 09:31 AM
Good luck
Tom
Pics of the mounts would be great, I'd like to make them look as close to original as I can.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 06-15-2017, 10:45 AM
Oak Oak is online now
Tim, I have one of those loaders too. I'll see if I can dig up some pics too. Those are nice loaders with the self leveling bucket design.
Old 06-15-2017, 11:01 AM
Good luck on the project Tim.
I'd put a single stick valve on it.
You can't do anything to repair the pits on the chrome. It may or may not eat the seals right out of it, but it will eventually eat them up. There is a company in Terre Haute, Indiana that can make new chrome rods. (Or a whole new cylinder if need be.) No idea the cost. Last I checked, it was cheaper to have a new rod made than to rechrome an old one.
Old 06-15-2017, 11:35 AM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
The single stick control is soooo nice to use!
I have found oftentimes that it is cheaper to replace the rods on smaller cylinders, too.
Tim, once you get that new toy looking terrific you are going to use it everywhere. They are not able to lift much...but you will try it anyway.
Queen Of The Quietlines!
Old 06-15-2017, 12:00 PM
For right now I'm just gonna clean the rams up and hope they don't leak to bad, I have plenty of projects I need it for so I wanna get it done and on the 108 asap.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 06-15-2017, 12:08 PM
Can I assume that since I've seen this loader with the spool valve on either side that the tower on the right is also fluid tight and can be used as a reservoir? I thought about switching the towers from side to side but it would require alot of cutting and welding to move all the brackets around. I'd like to add a filter to this also, anybody add one and have pics?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 06-15-2017, 01:42 PM
Good looking loader, Tim! Glad someone got it who will take care of it and use it. I've thought it would be nice to have one, but I don't really want to put on one a narrow frame. Maybe one day I'll get a larger tractor and have a loader.
