Cub Cadet 1720 carb
Well got the carb off the 1720. It would only run at full choke. Here is what I found. Full of water and gunk! Took it apart, soaked it in Berryman carb cleaner for 4 hrs. Sprayed it and all the ports and wired them out. Have to put it on tomorrow to see how it goes.
Ooh and another thing, the needle valve didn't even have a spring hooked to the float tab lol. |
I am thinking, this will make a difference and a vast improvement,
The water by itself would make it run pretty awful.
Richard 1979 IH Cub Cadet 782 w/CH20, dual hydraulics, power steering and Cat 0 three point |
IIRR that carb doesn't have the needle drop clip.
So it's not supposed to have a clip at all? Glad u said something! Thanks |
I don't think it did either. Lots of carbs don't. They aren't required, but do help prevent needle valve sticking on gravity fed systems. Not as big of a deal with a force fed system.
