Camshaft removal
Trying to remove camshaft in a k301a 12hp engine and need advice on how to remove it. What tools or do I need special type of puller?
Download and read this:
http://www.onlycubcadets.net/forum/s...ead.php?t=4646 Your questions will be answered. |
" Turn cylinder block upside down and, using a small punch, drive camshaft pin out from power take-off side of engine. Pin will slide out easily after it is driven free of block."
*Note; in this picture the engine is NOT upside down. I would recommend that you check the camshaft end play prior to disassembly. That way if you need any new shims, you can order them when you order your rebuild parts. http://www.onlycubcadets.net/forum/s...317#post388317 |
Rtfm
Do as JMech advised and read the pertinent info first.You'll be glad you did. Have fun.
Chris
1968 104 , service replacement '96 K301, 42" deck 1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck 2007 LA130,21hp Intek v-twin, 48" deck As you slide down the banister of Life, may the splinters point in the right direction . |
