https://www.walmart.com/ip/Berryman-...&wl13=&veh=sem better than just some spray carb cleaner. I use a wire from a wire brush to clean out the small holes in the main needle. Just pull the wire out of the brush with pliers, they're usually hardened steel. |
Spraying carb cleaner down the throat of a carb while installed on the engine does NOTHING to clean it. I don't know why people waste their time. All that does is clean the throat out..... which is not where the problems are.
I try the most economical & simple ways to get an engine running so if I can get away with cleaning the carb instead of taking it off & rebuilding it thats what will try first, if that doesnt work it will have to be removed & rebuilt its that simple. |
Spray away. It's your tractor. Might save you $4 or $5. |
Tried starting fluid & new spark plug, no fire no dice,
Thanks for your input. |
If you can't get it to fire with starting fluid then you don't have correct spark. Or no compression. Does it feel like it's sucking in the carb? There is only so much to go wrong here.
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
Thread Tools | |
Display Modes | |
