Greg Rozar AKA- CubDieselFan
Old 06-23-2016, 09:34 AM
Baccarat Baccarat is offline
Default Cadet 95 S/N dilemma
I recently acquired a Cadet 95e. In the deal it also included a second rolling chassis with the traction motor, tranny & rear end. The full blown machine has a scratch line on the S/N that wiped out the second last digit. All I read is 0340020U0084?1. There are only 10 options available. I plan on looking up the registry list and hopefully eliminate 9 other numbers and revealed the one missing one which should then be mine.
The rolling chassis has a full S/N of 0340020U007594.
Is my simplest option to restore the roller and then put all of the good parts from the 1st unit onto it and register as the second number? Or, would that be a no-no.
Mike
Old 06-23-2016, 09:57 AM
0084?1
That is the sequential serial number and has NOTHING to do with options.
0340020U
034 = Rear Engine Rider
0020 = Factory Code for the 95E model
U = Made in the USA
Roland Bedell
Buy: Made in the USA
Old 06-23-2016, 10:04 AM
lindstromjd lindstromjd is offline
U = Made in the USA
I think he meant "options" as in options for the missing digit; there are 10 digits from 0-9 and he wants to figure out what that digit is so he can register his machine.
Old 06-23-2016, 10:29 AM
I thought he was talking about "model options".
Roland Bedell
Old 06-23-2016, 12:02 PM
Yes indeedie, Lindstrom hit the nail on the head.
I had learned all the S/N info and meanings in previous research. I am still wondering about swapping out the frames and using the known full S/N in instead. I wouldn't want to commit a mortal sin and spend an addition month in purgatory.
The once or twice I bumped into the registry site it always wants me to register my machine first. I'm not sure where I can go to "Look Up" existing registered machines.
ML
Old 06-23-2016, 01:56 PM
ML
Why not just register the one you know, and then look to see if you can figure out the digit on the unknown?
Old 06-23-2016, 10:29 PM
Lindstrom
I hadn't thought of it in that fashion. I was more focused on the running one because the chassis one was more of secondary issue and would require more intense work. I didn't want to completely tear down the runner and put it all on the secondary chassis. As a result, I was totally focused on the runner first.
Thanks for the mental tweak to rewire my thought process.
ML
Old 06-23-2016, 11:01 PM
Lindstrom
ML
