Greg Rozar AKA- CubDieselFan
Old 01-09-2015, 10:43 PM
Moark Willy Moark Willy is offline
A tow behind mower might be a good idea.
That is not out of the question.
Old 05-02-2015, 04:43 PM
holeworx holeworx is offline
will a 1050 deck it a lt1046 with out any mods ?my 1046 has the 23hp mtr so 4inchs extra deck should be ok power wise
Old 06-19-2017, 06:15 PM
BonesD BonesD is offline
Talking
I see this post is a bit old but I was wondering the same thing about raising my mower to get more ground clearance. I don't need it for mowing but some of my paths are darn rocky and uneven and going slow doesn't always help. I have a 50 inch LTX1050. I mow in level 8, just a couple notches below high. I can't imagine mowing down at 1 or 2 but I guess different grasses require different heights. That aside, I can see that I could go up two inches(radius) and still clear the deck in the up position. The clearance grows as the deck is lowered. The front wheels would just clear the front shroud while sitting still.
Also it looks as though the mounting bracket could be welded lower on the deck as there is clearance above to tuck it in a bit higher, might cause some belt clearance issues though.
But, the info about overloading the transmission is enough to talk me out of it.
I know how to fix my problem by using my tractor to smooth out the rough patches.
Mostly I wanted to commend all the folks that responded to the original poster with such patience, most remarkable!
Maybe he could just over inflate his tires.
Old 06-20-2017, 04:14 AM
Cannon51's Avatar
Cannon51 Cannon51 is offline
I have about an acre behind the house that I went through and cleared the small trees and brush out of. It's rough as a cob. About once a month I go over it with one of my Cyclops tractors with the blades 5 or so inches off the ground. Every LT that I have tried to use back there I have torn up. I've bent blades and decks and busted spindles. I like LT's on small lawns but rough terrain is not the place for them. My opinion.
Cannon
Thread Tools
Display Modes
