Diesel problems
Plowed again with the 882 tonight and I think I may have a problem. It was blowing black smoke tonight when it would load up and after running it a while I noticed a loss of power. It starts fine, engine temp is normal but when you go from an idle to 3/4 throttle it will blow black smoke. It didn't do this before. When it's running it almost sounds like the exhaust is whistling and does not have the power it did Sunday. I have about 3 hours of run time on all new Wix filters, all new fuel lines and a new gas cock in the tank. I did run out of fuel tonight and got some off road diesel (I always use) and added the diesel fuel additive (Power Service - Diesel Kleen + Octane Boost). It was having a problem before I ran out and got worse after I refueled. Where should I start looking? Thanks.
Hmmmmm your new fuel petcock is open all the way isn't it? If so I would Check your getting a good flow of fuel from the filters and through the fuel lines,maybe change filters again?? If that doesn't help my guess would be something is wrong with the pump,esp since it's blowing alot of black smoke. Does it have a primary and secondary fuel filter? If they are reversed would it do that? Don't know if any of this helps,but its what I would try.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! |
Thanks Bocephus. The valve should be open but with a Cat 0 hitch on the back you can't get to it. It does have the original dual filter set up. I will remove the fuel line and turn the pump on to see how much fuel it is pumping. Has anybody adjusted the valves, checked the injectors or injector pump on a D600 before? Looks like it's time to start reading.
Have you checked your air filter? Sounds like you are either getting too much fuel now or not enough air.
Black Smoke...Fuel System Malfunction 1. Excessive fuel delivery 2. Restricted air cleaner 3. Defective muffler 4. Faulty injector nozzles Lack of Power...Fuel System Malfunction 1. Plugged fuel filter 2. Improper fuel 3. Faulty injector pump 4. Faulty injector nozzles 5. Faulty fuel pump 6. Restricted air cleaner 7. Low intake manifold pressure 8. Obstructed fuel line
Thanks DWayne. I will check them tomorrow along with the other things you have listed.
Hope you get it figured out soon. Nothing worse than a sick feeling diesel.
Black smoke on a diesel is always too much fuel or not enough air.
