Yes. Agree. Another job to add to the list.
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 70, #1 cart. Brinly Cultivator. Some wheel weights. {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
I usually cannot find the bolt on stem tubes so I Use a locking hemostat while assembly. I then air up the tire so the stem stays where it should. If I am putting fluid in just let the air out and have at it.
where to find the bolt on tubes for 23 10.5 12 tires? Im going to buy a bunch of washer fluid for my gts and it seems that some have not had a good experience with a standard tube!
i did look for them FWIW
1- 1864 Dual hyd, cat 0, axle braces 1- 1450 Dual Stick w/ power steering 1- 1200 in pieces 1- 1864 in pieces QA36A Thrower, #1 Tiller w/ extensions, IH windbreaker, IH wheel weights, 44C mower deck, 50C mower deck, CCC 54" Blade, GT46 high vacuum deck, GT54 deck, Cub Tripple Bagger, Custom dozer blade, Custom suitcase weights, 3pt cultivator, lawn sweeper, original R-Bucket |
Molasses is acidic. Heavy but you're talking same problems as calcium chloride
Good Job Steve!! You were lucky to get that stem back.. you must be a pretty good surgeon!
I've never had any issues with the standard tubes but I usually put a small locking vise grip on the stem while filling just for insurance.. Once loaded we run 8-12 psi.. never had any issues with the tire.. even on tractors that we work hard. I guess we are lucky... around here it doesn't get cold long enough to worry about freezing... so we just run good ole water
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
https://www.summitracing.com/parts/crr-321371/overview/ https://www.summitracing.com/parts/crr-321051/overview/ |
They used to be available without going to the ATV tube. Don't know when or why they quit making them. I used to buy them at my local tire shop for like $13 a tube. Not bad at all.... but now this is what they said you had to use as they quit making the 23X8.50/12-12 TR6 tube. Only difference I can see is it's a tube for a radial tire. Only means that they are designed to flex more. Won't hurt a thing to be in a bias ply. Only concern I have is if the stem is in the right spot. ATV's sometimes have the stem deep in the hub for protection. I haven't used any of these yet. But I need to..... |
Thank you very much Lance and Jon! Noticed that the bottom option had a 40 mm stem offset versus the 25 mm offset on the first link.
The one tube I used which had the metal valve stem with the hex nuts was a Firestone TR-6. Someone had written UTV on the outside of the plastic bag/package.
Thread Tools | |
Display Modes | |
