Greg Rozar AKA- CubDieselFan
Old 09-05-2017, 02:14 PM
Did you try using a 2 jaw puller?
The bolts go through the rockshaft oh mighty one!
I would drill out the bolts then just put new nuts and bolts on.
Up to 530 and counting...
Old 09-05-2017, 02:15 PM
sorner's Avatar
sorner sorner is offline
With the bolts still through the shaft how is a puller going to get it?
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower
IH Cub Original with deck
#2 cart
GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck
Old 09-05-2017, 02:23 PM
Looks like a job for the right angle grinder. Gonna be a PITA job, probably have to grind both sides.
Old 09-05-2017, 03:00 PM
sorner's Avatar
That's what I was afraid of. But I'll give it a shot. If I booger it up too bad, I have another rock shaft in a frame out back. Thanks all.
#2 cart
Old 09-05-2017, 11:26 PM
PeterJ PeterJ is offline
Dirty Steve has the right answer. Just hold a nut centered over the broke bolt and stick the wire feed welder tip in and weld it. It might take a few tries but that is by far the best method. The heat will help break the bolt loose.
Many years ago (before I had wire feed welders) a friend and I did this to remove a busted stud on a motorcycle header (1981 Suzuki GS1100EX) and it took three tries. It was on cylinder #3. We were worried about the heat being too much for the flange, but it turned out well. That was a much more delicate job than your lift arm.
You can do it!
Best of Luck,
PeterJ
1863 48" deck, 3pt
1864 x 2, 54" deck, power bagger, 48” deck
1811 44" deck 1210 44"deck
IH trip plow
QA42-A, 451 x 2, 551
42" Earthcavator
Driveway Drag
USAF
Shepherd's Chapel
Old 09-05-2017, 11:30 PM
One more thing.
Those lift arms are spendy little items. I just spent over a $100 ordering a push/pull one from Xtreme.
PeterJ
1863 48" deck, 3pt
IH trip plow
42" Earthcavator
Driveway Drag
USAF
Shepherd's Chapel
Old 09-05-2017, 11:40 PM
If you have a big enough puller, and a big enough impact gun, those little bolts will be like toothpicks.
I gots the big tools.... just sayin.
Old 09-07-2017, 07:12 PM
sorner's Avatar
And ruin the grease fitting while I’m at it.
None of that was necessary. I took Sam’s suggestion. I had the bolts backed out enough that I didn’t have to grind both sides but alas I got it off with no carnage. The 4” angle grinder with a cutoff wheel cut the arm in half, close to the rock shaft and a grinding wheel took the rest off right down to the shaft and it fell right off.
#2 cart
Old 09-07-2017, 09:27 PM
Dirty Steve's Avatar
Good job getting it off. They can be a real bugger.
Old 09-08-2017, 07:03 AM
Ya done good grass hopper!
