Greg Rozar AKA- CubDieselFan
Old 09-03-2017, 07:19 PM
jkmola jkmola is offline
So going off the 2nd link DM posted above - I do not have the 2nd fuse. Couldn't find one on the wiring diagram. So I started to test for a short and work my way through, guessing best I could about what was ok and not. Wasn't really able to really find anything that jumped out.
Starting thinking about that switch though. Have a 682 sitting around for me to finish a vanguard conversion. Swapped that switch into the 1811, and fuse didn't blow. Tried to start, and it fired. BUT, the starter keeps turning as long as the key is on. Switch is a different part # than the one in the 1811, and the contacts must be different internally. Switched the old switch back in, and it did NOT blow. But it wouldn't do anything when I turned the key either. So for now, it will sit until the new switch shows up. Hopefully that clears everything up. But it sure is frustrating to be this close and have to wait on a switch!
Old 09-03-2017, 07:38 PM
The Ignition Switch in the 1811 has an internal ground. I would venture to say, the internal contacts are messed.
Roland Bedell
Buy: Made in the USA
Old 09-09-2017, 07:57 AM
Finally figgered out what the hell was goin on. I had spliced on a Stens ignition switch repair harness (pigtail). Blue to blue, red to red, and so on. But the wires were NOT in the correct location inside the connector! So I had a blue wire goin to the terminal where a white should be, etc. Every one of them was wrong. So I corrected that and once I had the correct wires running to the proper terminals on the ignition switch - she fired right up.
Never thought to check that. Lesson learned
Old 09-09-2017, 10:18 AM
It is always beneficial when all the information is given.
Roland Bedell
Old 09-09-2017, 03:45 PM
Dart1917 Dart1917 is offline
He did in his first post.
Old 09-09-2017, 04:23 PM
I also replaced some crappy wiring behind the ignition switch with a Sten's repair harness.
In my world, a "harness" is way different than repair "pigtail".
Roland Bedell
Old 09-10-2017, 08:22 PM
It's all good. I simply called it what Stens calls it. Terminology be damned, as usual help was offered with a problem i had, in an area I know very little about. I appreciate every response and attempt to help and educate. Thanks again
