Greg Rozar AKA- CubDieselFan
Old 07-23-2017, 09:38 PM
Rick in Ontario Rick in Ontario is offline
Default LT1042 wiring diagram
I'm looking for a wiring diagram for my 2008 LT1042. I fond one, here I think, in the past but I cannot remember where I found it.
My problem is, I was mowing today suddenly everything shut off and it wasnt getting any electrical power, no electronic hour meter module, no power to the ignition switch. Checked the battery and cables and they're fine
I found a fuse that's kind of under the ignition switch (20amp fuse) that blew.
I put a new one in it and it cut for about 2 minutes then blew that one too.
That is why I am looking for the wiring diagram.
This site (http://manuals.mtdproducts.com/mtd/Public.do) only has parts and owners manuals, nothing that has a wiring diagram.
Any help would be appreciated greatly.
Thanks
Rick
Old 07-25-2017, 05:43 AM
I found a wiring diagram on the web.
Thanks
Old 07-25-2017, 07:32 AM
Welcome Rick. I found the diagram as well. Time to isolate the circuit in question as you probably already know. I would run it without engaging the deck and see if it still blows the fuse. That fuse supplies quite a few components in the system so you will just have to narrow it down. I fortunately have a DC amp clamp just for that but you can also get a 20 amp circuit breaker to install while troubleshooting so you don't go through so many fuses. Something pulling too many amps or possibly wiring shorted to ground, etc. Do you have a DVOM to do some volt/resistance checks?
