Greg Rozar AKA- CubDieselFan
Old 07-18-2017, 10:42 AM
Rob18 Rob18 is offline
Default PTO will not engage
I am having problems with my Cub 1170. After cutting grass for about 30 minutes, the PTO shut off and I have not been able to get it going again. For testing, I turn the ignition to the Run position and I have power at the PTO switch and when engaged, I have power at the PTO coil. However, when I actually start the tractor, I no longer have any power at the PTO switch. Does anyone have any idea what the problem may be?
Thanks.
Old 07-19-2017, 07:01 AM
First, welcome to OCC.......
Next, there are two different Wiring Diagrams for the 1170. It depends on the serial number range. What is your Chassis Serial Number..??
Roland Bedell
Buy: Made in the USA
Old 07-19-2017, 02:52 PM
I have a wiring diagram, but it is not exact, so that would be great if I could get the proper one. Model is 13AD608G656 and S/N 1A291H20183.
The PTO seems to be working now. After a lot of trouble shooting with no success, I took off and cleaned the ignition sw and PTO sw and the reconnected. It worked when I switched the key from RUN to Run w/lights and then back to RUN. Thanks
Old 07-21-2017, 07:18 AM
According to Cub Cadet....No Such Model.
Perhaps, it is model 13AD608G101....???
Roland Bedell
Old 07-21-2017, 12:40 PM
Sorry, model is 13AD608G595. It is a Canadian model, if that makes a difference.
Old 07-21-2017, 12:54 PM
Well, I would think it shouldn't, but one never knows. It would appear, that your tractor was made in the year 2000. There was production of this model also, in 2001, and 2002.
This model has caused me all sorts of headaches. Two different wiring diagrams and three different parts listings. Both the Parts Listing and the Wiring Diagram(s) are incomplete and confusing. I even called Cub Cadet Tech Support and there was 15 minutes of my life I will never get back.
Through all that crap, I think I have the PTO circuit figured out. It is different than the traditional CC circuits.
Roland Bedell
Old 07-25-2017, 11:22 AM
Wow, thanks for looking into this for me Roland. Much appreciated! Will you be uploading the wiring diagram?
