Greg Rozar AKA- CubDieselFan
Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Briggs & Stratton Engines
Old 02-02-2012, 11:58 AM
CHWNY's Avatar
CHWNY CHWNY is offline
Question 1641
Is there any common mechanical or electrical problem w/ the vanguard in a 1641? The owner says it was running fine now only fires on one cyl. his friend looked at it and said needs new engine. but did no tests! He is looking to sell what might a 1641 be worth?
Clay
Old 02-02-2012, 12:41 PM
Do you own this tractor? If so check to see if you have spark to both cylinders. It has 2 mags one for each cylinder. I worked on one a couple years ago that mice had built a nest in the blower housing and they ate one of the plug wires. They will go well over 1000 hours if they have been maintained. Check the plugs, do a leak down test on it. If it does need a new engine and your trying to get a value if the tractor is in nice shape I’d look to pay around $300.00 then I’d try to find a 2160 with a bad trans and pull the engine out of it and drop it into the 1641.
Old 02-02-2012, 03:27 PM
CHWNY's Avatar
I am looking to buy it, he wants 450. I think he is way high, I don't pay much more than 150 for tractors. There is not very many cubs around here! My thinking was spark as well but some OHV motors drop seats or other valve trouble.
Clay
