Greg Rozar AKA- CubDieselFan
Old 09-21-2017, 08:50 AM
Oak Oak is online now
I have a Prime Line part #7-01861-1 on my 882 and have had no issues in 5 years. Just Google that number and you will see a bunch of people selling it.
Old 09-22-2017, 09:39 PM
V30crewcab V30crewcab is offline
I run a ford starter solenoid. never had a problem.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 09-22-2017, 09:45 PM
A starter relay isn't designed for the amp load of a glow plug. A glow plug relay is a better choice. They look identical to a starter relay, but are made much heavier.... and cost more.
Old 09-23-2017, 12:48 AM
I would disagree. The 1772 use 925-3090 Circuit Breaker for their electrical system which is rated at 40 Amps. The starter on a 1772 is going to draw a whole lot more than 40 amps to roll over the engine.
Roland Bedell
Buy: Made in the USA
Old 09-23-2017, 08:15 AM
cubs-n-bxrs's Avatar
I ran a Ford solenoid for my glow plugs and never had a problem. I also bypassed the glow plug indicator in the dash as well.
Old 09-23-2017, 08:36 AM
A starter RELAY solenoid is a relay whose job is to engage the main solenoid on the starter. They are only rated at like 15-20 amps. You guys who are saying you use a relay solenoid may be using a starter solenoid, not a relay. No, I am not going to spend an hour looking up different part numbers to prove it. Just make sure you get a solenoid rated for at least 40 amps.
Glow plug relay's tend to have a higher duty cycle too.
Old 09-23-2017, 08:37 AM
My experience is that an auto/truck starter pulls many, many, more amps
than glow plugs.
Now I do admit most are not designed for continuous operation, but glow plugs are not continuous operation either.
--Just my thoughts.
Old 09-23-2017, 09:45 AM
I disagree. The size of the starter solenoid lugs (usually 1/4" x20) and the battery cable size (4 to 6 Gauge) are there for a reason.
Roland Bedell
Old 09-23-2017, 11:27 AM
Dart1917 Dart1917 is offline
I think J-mech is talking about a relay placed in the circuit between the ignition switch and the starter solenoid. The ignition switch would power the relay which in turn would power the solenoid. I've never seen this type of setup but I'm guessing he has. Such a relay would only have to handle the current draw of the starter solenoid coil, not the starter load.
Possibly we are all saying the same thing but our terms are where the problem is.
A heavy duty sol. that makes contact for starter motors in vehicles are going to handle several hundred amps.--- IE: Ford type sol. and a boat load more applications.
A relay that is designed to activate the pull-in- coil, of a starter sol. handles much less amps.
Many styles of relays as most know, are avail for various applications.
I, as well as many people interchange the term sol/relay.
The dictionary/google seems to also muddy the 2 terms.
Bottom line, if the rating of the contacting device is adequate, it should hold up to the riggors of the task
