SIMS Cab Refurb - 1872
Been working on a Winter project. A SIMS hard cab I bought several years ago from another member. It had been on a 682 but was designed for an 82 series super. Did not fit right on the regular length 82 series. Had some rust and pitting on the lower parts, guessing it was due to salt. So the refurb is to preserve it. I tried to do it right as it will be a lifetime keeper and a Winter workhorse. By the way I prefer a good cigar and a beer not the pipes.
Cheers, Rick |
Cleaned up the rough parts and coated them with POR15. Sanded the POR 15 when it was rock hard. Great stuff, I have used it on the bottom of mower decks and other tough areas with huge success. Then coated the parts where POR15 was with a special primer made for POR15. Note the POR 15 does great on bare or rusted metal but does not do well over the top of existing paint. The POR primer was brushed on some parts and smoothed out so well it looked sprayed. Only needed light sanding. I guess its worth the price.
Cheers, Rick |
Sanded and sprayed the other parts with two coats of primer and three coats of Valspar IH white with light sanding between coats. You can see the brushed on POR primer where I had used POR on the edges. The edges were very rusty under the weather seals. I then spray coated everything with regular primer.
Cheers, Rick |
I put 1/4" sheet rubber under the cab rear section, the fenders, and replaced the factory thin rubber footpad with the same 1/4" rubber. The extra height gets the cab foot mount up above the slight recess in the fender footwalls. This is to reduce vibration, provide a better seal, and match heights. Note the vise grips to keep everything aligned prior to drilling mounting holes in the fenders. The wood strips help alignment and prevent scratching the new paint. By the way, I let the paint dry for two weeks to get good and hard before assembly.
Cheers, Rick |
Its finally coming together. Hope t get it finished tomorrow. This cab was originally for a super without power steering (assume 982). I had to make a notch in the frame mount tab for the footwell to accommodate the bolt on the power steering cylinder. The finish on the footwells is a little rough due to pitting and POR but I expect them to last longer than me.
Cheers, Rick |
Looks great from here.
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 70, #1 cart. Brinly Cultivator. Some wheel weights. {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
Lookin GOOD Buddy!
Looks great!
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! |
Looks good, keep the pictures comin'..
Looking good!
Thread Tools | |
Display Modes | |
