Dozer/snow plow- attaching mainframe to subframe?
Went to visit the 42" plow tonight to mount on my 1450 but came across one stumbling block. It's probably pretty obvious but I wanted to double check here just in case . How do you attach the subframe onto the main frame? From the rubbed off paint marks, looks like you just use brute force with a crowbar or similar to wedge it on over the pin, then stick the cotter pins in to retain it? I almost started hammering on the rod but then realized it was welded in place
Yes that's it, pry it with constant pressure to get it on then hitch or cotter pin
A block of wood 1/2" longer or so wedged between the two rails will give you the room to get it on.
I used a small bottle jack and a chunk of wood on mine. worked like a charm!
"We don’t stop playing because we grow old, we grow old because we stop playing." |
I had to use a jack as well. Total PITA.
Daniel G. . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
Items you'll need:
Prybar Brute force Determination Various expletives
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
Alternative tools ----
Sawzall Welder
149, 2072, Original, 1772, 1782, #1 cart, Parker 48" sweeper, |
I use the lift rod of a 3 point hitch and always got them on in about 5-10 minutes.
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. |
Exactly. Don't be scared just get in there and force it.
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
Another note: unless you are switching it for a reason, just leave the frame attached. No reason to remove it.
Thread Tools | |
Display Modes | |
