Greg Rozar AKA- CubDieselFan
Old 11-15-2014, 06:30 PM
169kw 169kw is offline
Thanks for the pics..
169, Kwik-Way loader, 1100 (going to transplant a 10 hp Kohler in it)
Old 11-21-2014, 12:04 PM
cub123's Avatar
cub123 cub123 is offline
Your welcome, I'll try to get a few of it mounted later, I'll be pulling it out in the sun today if all goes well.
Small update, I took all the cylinders apart last night and put new O rings in them, hopefully that clears up the weeping and the cylinders leaking off with a load. I also put 4 new hoses off the valve. Ill try to get some pics, but Photobucket isn't working for me right now.
Old 11-21-2014, 03:17 PM
There is an article on the internet that explains it in great detail, but, if the cylinders move with a load, and there is no external leak, the problem can only be the valve,,,
As the piston moves, there is a volume change from one side of the piston to the other.
So, to hold a load, it said you could remove the seal (o-ring) completely,,,,,,
(If the rod enters the cylinder, the remaining total volume of the cylinder is less)
A cause for deep thinking!!
I don't know!!
Good looking loader!!
Old 11-21-2014, 06:20 PM
cub123's Avatar
CAD, thanks, thats an interesting thought, it was really only an issue with the bucket cylinders, so I think in that case with the smaller capacity side ( rod side ) leaking past the piston into the larger side was causing it. In any case the rebuild seems to have helped
On with the pics! All I have left is the 1" spindles/wheels, rear ags and the weights I took pics of the rear mounts as best I could, hopefully everyone can make them out.
Old 11-21-2014, 07:42 PM
POTW!
Old 11-22-2014, 01:56 PM
Jumper Jumper is offline
Cub 123, Nice clean and solid mount. Sweet job!
I hope there are no tears once you scratch the paint and get it dirty.
Old 11-22-2014, 08:29 PM
gt383mag's Avatar
gt383mag gt383mag is offline
cub123 what size are the cylinders for the main boom arms look like they have a really long stroke?
Old 11-23-2014, 09:31 AM
cub123's Avatar
POTW!
Good idea Sam, I'll do that as soon as I get it finished up with the weights
Thanks! I'll try not to cry too much, lol
I'm not sure, I'll have to measure them, they are pretty long.
Old 11-24-2014, 08:20 PM
cub123's Avatar
gt383mag: I measured the main cylinders tonight, from pin to pin fully extended they are 4'8" and they have a 2' stroke.
Old 11-25-2014, 02:24 PM
gt383mag's Avatar
thanks thats what i was wondering
