Greg Rozar AKA- CubDieselFan
Old 01-17-2017, 09:26 PM
Billy(OH) Billy(OH) is offline
Default 48" deck on 1782
I'm sure this has been discussed but I haven't found it. I have a 1782 with a 60" haban and would like to put a 48" deck under it cause it would work in my yard better. I found a 317190 48" gt deck that came off a 1641. Will the frame off the 1641 work on mine or will I need to find a frame for it? Thanks for any advice
Old 01-17-2017, 11:09 PM
CubDieselFan's Avatar
It will work. Go to the Cub Cadet website and do some part number comparisons to see what is the same.
Old 01-18-2017, 12:40 AM
If you only need a 48" deck, just go buy a GT. What do you need a SGT for if you only need a 48" deck. I suggest either getting rid of the super, or adding a second tractor for mowing duties. Whatever... it's your stuff.
The 1782 was made to accept a 46", 50" (50C), 54" or 60" deck.
Just go look up your model of tractor and choose "attachments" and it tells you. If you don't know how to look it up, I'm sure someone will walk you through it.
Old 01-19-2017, 01:31 PM
PGHsteelworker's Avatar
PGHsteelworker PGHsteelworker is offline
he model 317, 48 inch gt deck and the model 324, 54 inch deck, will both fit on a 1782 and use the same attachment frame assembly and works very well on a super.
Old 01-19-2017, 02:00 PM
Same frame, different lift links and belt and you move the deck carriage to the rear holes on the mule drive.
Old 01-19-2017, 06:36 PM
OK. Thank you for the response. I was confused about the parts listing have a adaptor on it but didn't realize it was just the links and belt. I found one on eBay bout an hr from home that isn't in to bad of shape.
