Greg Rozar AKA- CubDieselFan
Old 05-12-2018, 07:40 AM
CUBRAT CUBRAT is offline
Default Can a K301aqs off a JD212 be swapped with my Cub Cadet 1200?
Hello all!
I found a JD212 that has a good running K301aqs. The engine in my Cub 1200 smokes a little. Would I have any problems swapping these engines out?
I know some parts outside the engine may need to be swapped, but is the block, crank and everything else the same?
Old 05-12-2018, 08:05 AM
Usually the crank is different as well as the oil pan, you may be able to switch pans but I can't guarantee it because there are a few different style blocks. How bad does the Cub engine smoke? These engines will run forever smoking. If you're getting the Deere cheap enough you may be better off to clean it up and resell it and take the money from the sale and rebuild the Cub engine.
Old 05-12-2018, 08:25 AM
jbrewer's Avatar
jbrewer jbrewer is offline
I agree with Tim. Oil is inexpensive! :-)
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 05-12-2018, 10:14 AM
Lanceskene's Avatar
Lanceskene Lanceskene is offline
Nope, the 212 engine sits sideways in the frame and has a manual PTO so the output shaft on the crank is differant, you could swap the the crank, oil pan, and flywheel but at that point your rebuilding an engine so your better off working with the original Cub block.
Lance / Alberta Can
IH 127 w/deck, snowblade
IH 154 Loboy(x2) w/creeper 3pt and 3160 deck
CCC 12.5 w/deck
Plus 35 or so non IH tractors
Old 05-12-2018, 11:03 AM
What Lance said.....
Roland Bedell
Buy: Made in the USA
Old 05-12-2018, 05:26 PM
Bummer. Thanks for the info guys!! I guess Ill end up rebuilding this one. This 1200 seems to be a unicorn of sorts!
This one is my first Cub. I traded for it on spot, didnt get to research it. I'm finding out real fast that I shouldve started with a narrow frame, LOL!
So far, mostly new drive shaft and components, new ISO mounts and changed some nasty fluid out of the rear end. I'll probably pop the head off soon and see if maybe the head gasket is causing some smoke.
Maybe Ill get lucky.
