Greg Rozar AKA- CubDieselFan
Old 03-02-2015, 01:55 PM
fleetlines's Avatar
fleetlines fleetlines is offline
Default IH Cub 154 rear PTO in an "O" or 72"
Would the rear shaft PTO from a IH Cub 154 fit in an Original or 72? If so, what do I need to look for in it and what range should the price tag be in?
Original, Serial #44578, K161S Serial #659144, 3pt. w/ Spring Assist, Deck, Fenders, Lights
72, Serial #231093, K161S Serial #C281773, 36" deck
149 & Original Yard art
1650, Serial #2050067U559932*, K341 Serial #7133367, 3 pt. hitch
1650, Serial #2050670U601762*, K341 Serial #7584702 SIM cab, 50" deck, tires loaded & weighted
123 FEL and weight box
10" & 12" Brinley Plow, Decks, Roller, Cart, Power angle blade, dozer blade, Snow Thrower, Airator, Tiller
Old 03-02-2015, 01:59 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
I am pretty sure the "O" used Farmall Cub rear PTO parts.
Old 03-02-2015, 02:14 PM
The big problem is that the F-Cub's top shaft for the trans is different. Your 72 (unless it had a rear PTO and it was removed) won't have the top shaft to drive the PTO. Good luck finding a top shaft for a PTO for sale by itself. It happens..... but not often.
The PTO itself is the same.
IIRC, the top shaft for the trans on an O is different that the later cubs, and still not the same as the F-Cub.
