you should call them to be sure.
That part is correct for a 12" cub cadet rim. these are them on my 107.
Too much chrome, I don't do shinny stuff. Oh Yeah I'm lazy.
As they should!
Tankman '95 CCC 1641 Eastern PA USMC |
Back in the 60's early 70's, they were plain ones offered by Sears for their GT's. Such as, Suburban 12,14, 16 and etc. I see them popup on E-bay every now and then. I have a set on my 149.
Don B, USAF 1962-1968, Ft. Wayne, IN |
Here's how Mooney responded: Most likely it’ll have to be screw on type discs, but if it’s on tractor and don’t drive too fast, then Velclo, or double sided tape might be sufficient to keep them in place. What we need from you is overall diameter measurement on wheel where you want discs to sit in. our regular 12” discs measure 12-3/4”. If you can let us know that measurement, we can make them up for you even if it’s not 12-3/4” for additional charge. Thank you!
Because they are ugly. Hub caps are for cars, not tractors.
I guess you're right, work.
Reminds me of 4-wheeling on the desert when I lived in AZ. Knew the chrome polished wheels on 4-wheelers meant, "I look cool but, I don't work!"
Adding chrome, fancy paint and other bling to a Cub cadet is no different than doing the same to trucks, semi's, etc. None of it makes them run or work any better but it still gets done.
Those 12-3/4" dia. disc would fit just inside the turn out on a 12" CC rim. Which hubcap was Mooney's talking about there? the spun aluminum one? |
Thread Tools | |
Display Modes | |
