Greg Rozar AKA- CubDieselFan
Old 07-19-2017, 08:49 AM
blues2us blues2us is offline
Default Kohler Coils
My 2186 18 hp Kohler quit on me yesterday an hour into cutting. Was running fine then started stuttering and finally stopped within about 20-25 seconds. Oil level is good so it wasn't the low oil cut-off cant find any broken or shorted wires and fuses are good. There is no current going to the spark plugs (either one). My cub dealer said more than likely the 2 coils or the kill switch wire next to them. Can they (coils) be changed without pulling the engine off ? If so, what is the best way ? Or does the engine have to come off ? Any help would be appreciated.
Thanks,
Blues
Old 07-19-2017, 08:52 AM
The engine needs to be removed. But it is highly unlikely that both coils failed. You need to do some diagnosing before replacement.
It could be a shorted wire, bad ignition switch or other wiring issue.
Old 07-19-2017, 09:02 AM
Ditto. You have a better chance winning the Lotto than both Ignition Coils going bad at the same exact time.
Roland Bedell
Buy: Made in the USA
Old 07-19-2017, 01:05 PM
Sounds more like a fuel problem.
