#21
Photo of relay
attached is the photo of the relay
#22
The previous information would have worked. It was a SPDT Relay while the one on the 2072 is a SPST Relay (No normally closed contacts)
The 2072 uses a 725-0894-----> 925-0894 Relay. Here is a Diagram of how this should be wired. Green wire is Ground Brown wire to Control Circuit Brown & Green is the Relay Coil White wire is Power Source (12VDC+) Black wire to Elec PTO White to Black is the Magnetic Switch contacts When asked to run a jumper wire from the Battery (+) terminal to the Brown Wire, if all was good, that relay should have energized. The White Wire has 12VDC+ as long as the Ignition Switch is in the "Run Position". Since the White Wire has 12VDC+, and the Relay is energized, then the PTO will engage.
#23
Fixed!
I should have paid more attention to your directions.
Indeed, one of the brown wires on the seat switch was disconnected. It works fine now. Thanks for your help! |
#24
#25
Still trouble
Hello Roland,
After having thought that things were fine when I reconnected the brown wire to the seat switch, when I put it in reverse during the first mow, it quit working and I had to use the rubber band again. So, I bought a new seat switch and boot and installed that and cleaned the wires and used the electric lube and still a no go! What can I try now? Mark |
#26
Well, since it has been a couple of months now, I'll have to go back and re-read the posts to refresh my memory.
#27
Is my understanding correct, that you have purchased and installed the following new Cub Cadet Parts:
* PTO Switch * Holding Relay * Reverse Switch * Seat Switch In addition, that the 2072 tractor is wired per the factory wiring diagram...???
#28
Yes, all have been replaced. Remember, it ran fine for about a year after I moved it to Minnesota. When the toggle stopped working, I replaced that. Then the relay. Then the reverse switch. Now the seat.
#29
AGAIN....did you run the Jumper Wire Test, from the Battery (+) post to the Brown Wire on the Holding Relay..???
#30
When I touch the relay terminal that the brown wire would be connected to, the relay opens/shuts.
When I touch the brown wire (not connected to the relay) nothing happens. |
Tags |
2072, pto switch |
