Greg Rozar AKA- CubDieselFan
Old 10-17-2017, 06:04 PM
BThein's Avatar
BThein BThein is offline
Default Couple of Pick Up's
Been awhile since I have had any Cubs in the shop,got to missing them.So after picking up a Haban blade I went looking for a Super to hang it on.I almost passed on this very tired 2082 but the price was way too good so into the truck it went.The 2082 was engine-less so had to find a donor and this is what I think is a 1862 came along.I just put a little two cycle fuel down the engine and she ran till it was gone sounded pretty good so hope I can make something work.Should be a good winter project for me they each came with a deck and mule drive but nothing to write home about.Took a few quick pictures to prove it really happened .
Bob
Old 10-17-2017, 07:02 PM
Nice pair of
C
u
b
s
Up to 530 and counting...
Old 10-17-2017, 07:30 PM
sorner's Avatar
sorner sorner is offline
Ah, you got the leaders heights one. I had been thinking about it but decided to pass. I have enough Cub carcasses at my compound right now. He lowered the price to $100 from $300 when I had first seen it. I thought it was an 1862 but someone changed the listing I posted in the Craigslist to 1541.
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower
IH Cub Original with deck
#2 cart
GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck
Old 10-17-2017, 08:24 PM
BThein's Avatar
You know,it very well could be a 1541 I will check the serial number.I may be wrong but I thought the only difference from the M18 was the carb they used to limit the HP.
Bob
Old 10-18-2017, 06:41 AM
ccpullin ccpullin is offline
Bob
Check the spec # on the engine or pull a head. The lower HP twin engines used dished pistons and low compression heads (combustion chamber machined out over the piston). Same bore/stroke as a M18.
Old 10-18-2017, 12:45 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Looks like the PO ran the tires off of that 2082.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 10-18-2017, 07:37 PM
BThein's Avatar
Thanks for the engine info,I stand corrected.I did take a quick look at the tractor and it does have an M18.
Bob
Old 11-04-2017, 05:18 PM
BThein's Avatar
Well I have been picking away at the old 2082 ,first pulled the Mag 18 from the donor tractor.I went ahead and tried to save myself some headaches ,pulled the tins and starter when it was out.Cleaned out the mouse houses and so forth but was fairly clean .I cleaned and lubed the starter and then dropped the engine into the 2082 .I had to straighten out some wiring that was melted and replace the key switch . It now runs and yard drives even took time to paint the JD rims and find some tires . Still needs lots of work, I took a few pics to prove it happened .
Old 11-04-2017, 09:00 PM
Odd..... parts books show they use the same parts. Can you verify? Pics? Parts book that shows this?
Thread Tools
Display Modes
