I finally found a hydraulic repair shop that said they could fix the cylinder but when I took it in they told me it wasn't worth fixing. The guy said it would cost $100.00 just to take the cylinder apart! Sooo, I think I'm going to try and take this apart and fix it myself. I worked out a deal with the seller (got a good bit of money back and kept the parts) so it won't be any more of a loss if something would go wrong.
Did you try the cyl with hyd pressure? I've seen them leak/bleed at rest, but not leak under pressure (but they are going bad soon) If the seal is held in the gland end with a snap ring/circlip etc. You can cut off the rod clevis/end and replace the seal. Then reweld the end OR thread the rod and replace the end with a heim or Hemi joint. OR you can cut the cylinder @ the welded end/gland, remove the piston assy. to facilitate removing the rod from the seal, then replace seal/reassemble & reweld the gland, which is a more extensive repair |
Guy's, you can get these cylinders off ebay for under $15 all day long. Dealing with the welded end is just not worth it for that price.
Sold everything but one. 1211-snow pusher, cab ,54 inch plow, loaded tires (all 4) Gilson wheel weights, X-trac fronts- soon to have power steering and dual hydraulics |
What size cylinder is needed? Do you have a part# so I can search this on ebay?
1450 Dual Stick Hydro | 42" Power Angle Blade | Model 1 Tiller | Homemade Wheel Weights RZT 50 |
In the end, I don't think anyone will find an angle kit that doesn't have a leaking cylinder.
Red '84 Cub Cadet 782 50" Deck, 54" Power Angle Blade, QA42 Blower, #4 Cart, #2 Cart, 400 Rear Tiller, IH Rear Grader Blade, IH Rear Rake, IH CI Weights, Rear Suitcase Bracket, Sleeve Hitch, Front Hyd. |
Guys, if you look at the date of that post it was made 01-20-2011, 05:17 PM
Edit: That said here is a NOS kit http://www.ebay.com/itm/Cub-Cadet-Po...item1c4e7e25a2
also didnt J mech post a while back about some place making these new now
982D kwik-way loader w/3 spool control and front and rear remotes,2182, 1812 cat 0, 1440 puller, 3185 grass killer, 2x 450s, QA42, 364, tiller |
Thread Tools | |
Display Modes | |
