#71
Got the box all welded up and new chain cut, new gasket made, put both sides together yesterday and put the pulley and locking collars on this AM, I shoved a quart and a half of 00 grease inside, I oiled everything also. There is a chain adjuster you have to trap between both case halves, I used grease t hold it somewhat and a car antenna to guide it in place.
#72
I pulled the rear cover and replaced the gasket and mounted the gearbox bracket. Gearbox looks nice inside. My belts came in at the store.
#73
Your having way too much fun.
#74
Got it hanging on the back, still waiting on two bearings for the gearbox.
#75
Just finished putting the gearbox together, I replaced the seals and outer bearings and new grease inside. Cut a new cover gasket from cork. No vent or fill plug on this thing, seems sealed once together. Got some parts ordered to finish the PTO also(needed one new screw and a triangle spring, one of mine had a broken tip), as well as an INTERNATIONAL decal for the back. The tiller seemed to have a tight spot when rotating, I backed off the chain adjustment and all is good now. They stress in the manual finger tight only, I had cranked it down pretty tight with my fingers, guess it was too finger tight(I did hand tight maybe?).
Still haven't bought any tines yet...had a card in hand and called that Outdoors place, and their computers were down... |
#76
Usually the outside and the ones facing the gearbox wear the most. I have rotated the tines on a few horse tillers that I borrowed before getting my own. By moving the inside facing ones out and outside ones in with a little mixing and matching you can usually get full coverage again....unless they look like Sam's, his were whooped.
Bill |
#77
My excluders were fubar from the shaft wallering around with bad bearings. I used a Dorman #299-020 washer with 1.125" ID slipped onto the shaft after the excluder, this was tack welded 3 or 4 spots then removed and spot welded all around. Should keep out the big chunks. I ordered new felt seals. Mounted the gearbox and used a 3VX530 Gates belt. Waiting on felt seals and some PTO pieces now.
#78
What a great job, thanks.
#79
Got a decal for the back.
#80
What did you fill your 90° gear box with? Or is that what your waiting on bearings for.....
Thread Tools | |
Display Modes | |
