Greg Rozar AKA- CubDieselFan
Old 01-11-2018, 12:22 PM
deschije deschije is offline
Default QA-42A Issues
Hi folks. Reading through these threads has led me to believe that this is home to the most knowledgeable Cub Cadet owners on the planet. Hopefully you can lead me to a solution for my dilemma. It has two parts:
Firstly, I decided to clean up my snow thrower this year and as part of that process, I cleaned and oiled the threads on the belt adjustment lever on the left side. Since doing that, I went through three belts (it didn't help that it was almost two feet of heavy snow). Each time the belt tension slackened and burned off the first two belts. Since they were old, used stock in my basement and beginning to fray, I went out and purchased a kevlar belt which lasted for maybe an hour before the same thing happened. The problem is that I cannot get the tensioning screw to maintain the proper tension. I looked at countless sites to figure out how to fix this. Some maintain that the four bolts on the plate assembly have to be tightened after the tension is set but with the little spacers, the plates still slide up and down. I've only been able to solve the tension problem by removing the spacers and then tightening up the carriage bolts so the two plates are securely pressed against each other. But that's not the proper solution as they wouldn't have put the spacers in there in the first place unless they were necessary. I've seen a reference to a clip that will not allow the adjustment bolt to turn out. Is that the solution? Rig up something to prevent it from turning?
My second issue is that the blower won't lift high enough on the right side (where the lift bar attaches). The left side moves up high enough but somehow the right side sags. I would've thought that the right side would be higher (being directly connected to the lift bar) and the left side might sag but no. After reading some other posts I've checked the tire pressure in all tires and it is as per spec. I checked the cam limiter thingy by the right foot platform but it is not coming into contact with anything. Any ideas?
Old 01-11-2018, 12:49 PM
Yes, there is supposed to be a locking tab on the adjustment screw. I'm not where I can post a pic. Maybe someone else can. If not, later I will.
On the lift: perhaps something is bent on the blower lift frame. Could also be a mount issue. Look everything over good. Post pics of the lift if you can find the issue. We can likely see the problem.
Welcome to OCC!
Old 01-11-2018, 05:04 PM
RLause's Avatar
RLause RLause is offline
I had the same problem. Positioned the handle vertical, put two wraps of wire around the top part, hooked the wire behind the mounting bracket, problem solved.
Richard
Old 01-11-2018, 05:47 PM
Stephen.Mellish's Avatar
Stephen.Mellish Stephen.Mellish is offline
To stop the adjuster from backing off you can do what member finsruskw did.
http://onlycubcadets.net/forum/showp...9&postcount=34
The Collection, so far: Cub Cadet 100(x2), 125(x2), 123(x2), 70, 71. Adding more when I can find them.
Old 01-11-2018, 09:54 PM
Gompers Gompers is offline
Welcome to OCC!
The one labelled 1 in this photo, I believe.
Mine doesn't lift entirely evenly, but it definitely goes up and down enough on both sides.
Here's a video of my QA-36B lifting on my 782 https://www.youtube.com/watch?v=N5J_mTUFJiE
Do you have a QA-36/42 or a QA-36A/42A? The 36A/42A have additional lift linkages, and it's a slightly different mechanism because of that.
Old 01-11-2018, 09:58 PM
Mine doesn't lift entirely evenly, but it definitely goes up and down enough.
There it is. I hadn't gotten around to finding a pic yet.
The OP says on the title of the first post it is a QA42A.
Old 01-11-2018, 10:06 PM
Whoops. For some reason I thought this was a post in the QA-42 issues thread!
Snowthrowers are apparently popular this time of year for some reason...
