Let's push snow in the dark, shall we?
I have always enjoyed snow removal in the dark. Something about the way a tractor illuminates the night in a way that only happens in winter and making it do work is fun for me. I did a bit of snow removal the other night and captured it on video. Hope y'all enjoy.
https://youtu.be/6t0PttdFwIY
Daniel G. . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
great video , hard to beat an old cub plowing !!!
I wish I had some snow here
JD x475 |
Nice vid! I also enjoy using the cubs at night esp in the winter!
Good video Daniel. Thanks for posting.
Better you than me...
Make the best of each day , Todd Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
related question... how much more amps will 100 watt headlight bulbs draw vs 35 watt bulbs? (running 2 of them in either case) wanting to use these, mostly since I have them laying here collecting dust.... don't have to go buy, so they cost me nothing.... got them from a buddy of mine some years ago. same size, fit just like the regular ones.... also are 12V rated. . eventual plans are to go to LED's.... which I know will drive the amp draw downwards even compared to stock 35 watters...... but right now I have a tractor that looks like Popeye and I am trying to get ready in case I need it for snow duty....
Watts divided by volts = amps. So at 12 volts the 35 watt draws about 3 amps and a 100 watt a little over 8.
ok so if I put 2 in, then it will be a little more than the 15 amps that my kohler puts out at full tilt. thanks. getting ready for snow that I hope doesn't show up in the 1st place.
Yep some have all the fun! May look even better with some Christmas LED light on that cub Daniel!
I always do the snow removal nighttime! No traffic and it so quiet, you can ear your paw "skouiking" in the snow as you walk to your cub, it's you and your machine against the element! You fight few hours, came back home for a hot coco, sit in front of a warm firework or your 70" TV... Mission accomplished, you have survived another day. The problem is you need more power then your alternator/stator can produce so you drain your battery and overload the charging system . I use 2X50W halogen with success so I stick with that on all my cub for now, I try few LED beam and anything under 24W (8X3Wcree) seem less powerful.
Gilles. 1988 2072 401 54" hyd angled blade 1988 1872 364 snowblower/C50 deck 1976 1650/QA42A blower/44A deck/standby 1976 1450TS/Sleeve hitch/44A deck/in storage 1963 100 (red)/in storage 2010 Kubota 2380-2/42" infinity deck (engine swap) |
Well, you could wire them in series instead of parallel. That would cut your current flow back to around 4 amps but you would only get 50 watts out of each bulb. Also if one bulb burns out the other won't light.
