#21
Well it's really a 20 footer ! I did a little touch up on it but at some point in it's life someone took some hateful grit sand paper to it and slopped on some brush paint I think still looks good till you get up close and you can see the results of someone's quick do over .
#22
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
#23
There are not many parts and components that come together to form these awesome IH Cub Cadet garden tractors that can not be rebuilt, before being replaced!
Also, with the parts I sent, you know what you have, where a used pump could be a 50/50 crap-shoot in the real world where deals don't normally exist. You also got a terrific deal on a spare pump
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
#24
John, that's to me the primary draw to these old machines. They were meant to last and to be repaired when something wears out. The sheer number of survivors is testament to that. It's mighty nice of you to help out as you did and I'm really glad another one is being used again!
#25
Just to pile on, I replaced a few pistons/slippers on a hydro a couple years ago in a restoration. They fit in the cylinder block nicely, and it's back in operation and works fine. Can't say it will last another 40 years, but for my purposes, it was the expedient thing to do. On another project, I did buy a used hydrostat, and it's working fine, too.
If I were building or repairing a unit that was intended for 40 years of heavy use, I'd follow the mfg instructions not to mix up pistons/cylinders, etc.
Nice job... if I had a quarter for every time I was told not to do something because it's not the right way, or the manual says not to do that, I'd have at least 75 cents profit (because I spent the rest on curing my yellow fever ). I rebuilt a power steering cylinder a while back by cutting it open with a hacksaw, replacing the seals, and putting it back together... against all advice and everything. I've used it quite a bit and no problems yet. If you're careful and doing the job with good sourced parts, you can squeak by with undocumented/not recommended repairs.
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower IH Cub Original with deck #2 cart GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck |
