#31
#32
Just put your finger over it and it will be fine.
#33
I agree. i could live with it but wanted to point it out so the OP didn't buy it and find out when it arrived.
#34
That dash plastic is pretty popular and used on quite a few models, with the only difference being the number of holes drilled for gauges and indicator lights as mentioned. It's common for them to break out right where the mounting screws pass thru the plastic. Look closely at any used dash you might find and make sure that the hole is smaller than the head of the screw that lives there.
149, 2072, Original, 1772, 1782, #1 cart, Parker 48" sweeper, |
#36
Hmmm....makes me wonder on the 782. I saw it about 3 months ago. Had a bad engine or I probably would have scooped it up. Can't recall the steering wheel center cap, I think it was the plain one. I was just excited when I saw how it was built and the real low serial #.
RUN IN THE RED 782 w/50c deck (red); 782 dual stick, 44c deck (y/w); 1050 w/38c deck; 1864 w/54" GT deck; 1872 project Cub Cadet Pro Z 560 L 42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper 1200, 1863, 1864 parts machines |
#37
If it was a repaint, it would have had a high IH serial number.
Although technically, it could be a low CCC number and be a repaint. But I'm not sure why they would do that as CCC offered both colors. |
