Greg Rozar AKA- CubDieselFan
Old 11-26-2014, 01:54 PM
jkier's Avatar
jkier jkier is offline
Is the center paddle on the auger still intact?
106 Needs a clutch-------107 (Lent to my brother)
123 w/hydro lift & qa36--126 w/creeper and lift
127 restored--------------129 50" mowin machine
129 w/hydro lift-----------147 plow horse w/tiller
149 auction score---------782 KT17SII
Old 11-26-2014, 01:55 PM
sth5591 sth5591 is offline
Not as far as I can tell, it will occasionally catch a clump and throw it, so I'm pretty sure its not
Old 11-26-2014, 02:47 PM
cubby102's Avatar
cubby102 cubby102 is offline
Could u get a picture of the auger? Something isnt right at all here I dont think ive ever had this issue and ive moved everything from almost solid slush to powdet
1872 - 60"haban 54" power angle haban blade
'63 Original - restoration project
582 -tiller
147 - leaf duty with bagger.
1811 - Ditch mower
800 - have it just cuz its a 800
Old 11-26-2014, 03:06 PM
Sure, I had no issues with it last winter either. This is the first attempt this year.
Old 11-26-2014, 03:45 PM
Well I think the PTO clutch finally bit the dust, the temp dropped a few degrees which seemed to fix the feeding issue, and I went about 15 feet and the belt stopped spinning entirely...
In order, the feeding issue I was having, snow just piling up in front of the auger, even though it was spinning well at the time.
2nd, the auger, not the prettiest but it works
3rd and 4th, the sheared bolt for the PTO clutch to engage and disengage
Berwil's Avatar
Berwil Berwil is offline
Have you tried spinning the auger by hand...with the tractor off of course. If the pto is always on, spinning the auger should turn the motor. I'm wondering if something isn't sheared, like the pin that holds the gear on the transfer shaft. The gear is a tight enough fit on the shaft it would spin the auger till you hit snow, then slip. If yours is like mine, there is enough grease around there to keep it from burning up as it spins and mask the problem. Just a thought.
Edit: looks like your problem flushed itself out.
Bill
Old 11-26-2014, 03:55 PM
Yeah, now when I hit the snow I can see the driveshaft for the auger stop spinning, and the belt will stop too.
Old 11-26-2014, 03:56 PM
So, anybody have a good link on how to rebuild the PTO clutch? And also anywhere I can find the parts?
Old 11-26-2014, 05:45 PM
Try our sponsors at the top of the page.
