#21
#22
I had an IH spring on my 122 and the same spring shown on my 125 ( maybe it was the other way around? ) and couldn't tell the difference between the two using the same implements.
The only difference is the bolt on the spring. |
#23
Hope it works out Gene but you know, Lew gotsta eat too.
Make the best of each day , Todd Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
#24
I know what you mean Gene.
#25
Nick you mean your dads paycheck. .....
#26
Hey i chipped in with cash both times too Lew.
#27
Atta boy Nick.
#28
#29
If a source for the correct type (strength/wire size etc.) spring could be found, these would not be that hard to fabricate.
Which spring is it from TSC?? Got a part number or UBC code by any chance? I'm a long way from any of their stores where I live. |
#30
If your low cost attempt doesn't pan out, don't hesitate to get a spring assist setup. It will last you forever and it will save your arm. I've had one for 30 years and it makes the job easy without winches, wires and hoses.
Now I'm not saying that if I had a nice hydraulic setup I wouldn't take it but compared to the grunt method the spring is super! Added benefit, your arm doesn't ache for days after plowing. Good luck.
Randy Cubs: 71, 72, 127, 149, 1440, 2186 and 1864 John Deere 110 round fender John Deere 140 H3 Sears: GTV16 |
