I wasnt suggesting I knew which one it was.... just pointing out that TD shows two very similar machines, either way the seller doesnt seem to know anymore about his machine than I do.LOL
Lance / Alberta Can IH 127 w/deck, snowblade IH 154 Loboy(x2) w/creeper 3pt and 3160 deck CCC 12.5 w/deck Plus 35 or so non IH tractors |
So how does the auto gear work? I see the fwd and rev pedals so do they operate similar to a shuttle shift on a larger tractor or is it completely different?
-Wes '67 125 48" Deck, 1A Tiller, 36" Snow Thrower, Push blade '03 2166 42" Deck |
The AGS auto gear system is a 6 speed manual trans. In front of the trans is a forward and reverse wet clutch. You put it in the proper gear for what ever speed you want then push the forward or reverse pedal all the way down and hold it all the way down. What kills them is that people think they are a variable speed hydro so they don't keep the clutch fully engaged. Even a lot of the dealers didn't understand that they weren't a hydro so they instructed new owners incorrectly. I was at a Cub dealer the other day and they had an AGS tractor in the shop. The salesman told me it was a hydro, I had to educate the boy.
This is an exploded view of an early design 2160 clutch. For what it's worth I understand that the early design 2160 clutch's can be shimmed. The early clutch has caps with 3 bolts that can be removed the later design does not have the removable caps. I remember a thread years ago on MTF telling how to do it.
Thread Tools | |
Display Modes | |
