#21
Very nice. I contemplated putting one up like that at my place but want to move back down south soon
-Rick IH 782 IH 126 CCC 1863 |
#22
Congrats, looks great. And it's RED, that's a plus, unless you like Deere John's.
So, what's the inside going to have for creature comfort? Lift, drain, office for big screen TV? Loft for storage... What are you going to heat it with? Come on man, gotsta have the details...
Make the best of each day , Todd Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
#23
By the way, how many of you sealed your new concrete floor? |
#24
I built a new 30x30 shop in 1998.... we laid really thick black plastic sheeting down before the slab was poured and I asked the concrete finishers for a really slick finish.. the guy stayed all day with a power float working it.
I never sealed it but I don't have any moisture problems and oil wipes right up off the floor and it sweeps real easy because it's got such a nice finish... so I never saw the need for paint or sealer.
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
#25
The water just "bubbles" up. Drys up super fast after using a squeegee.
#26
Seal and cure concrete sealants are helpful as they hold moisture in the concrete thus slowing the cure rate. Slower cure = stronger concrete that's less likely to crack. Should be applied as soon as possible, like as soon as you can walk on it. Also helpful to keep dusting down, such as when you have an attached garage and you want to minimize the amount of dust tracked into the house. I always seal all of my concrete work.
By the way, nice barn! Pole type construction?, floating slab?.. |
#27
Yes, floating slab and pole barn construction. 2x6 wall girts, 6x6 posts, 2x4 roof girts on edge. Pretty solid. Very pleased.
#28
One of the things I really like about pole construction is the minimal site disruption. Do the local codes make you put the posts on footings? |
#29
Gravel in bottom of hole; post installed; concrete collar with top of concrete about 6"-8" below finished grade. All per County requirements.
#30
That's great, even less site disruption. Less excavation + less formwork = lower cost. Plus, a very rugged structure. Very nice!
