Raising mower deck
I just bought a 127 with a 48in mower deck. The cutting height when on the highest setting is only about 3.5 inches. My 123 deck raises much higher. I use them to mow around the farm, not a nice grass lawn, so 3.5 inches is too low. Anyone know how to raise the deck? The lift linkage seems to be raising as it should as compared to the 123, tires are aired up, the adjustability on the deck is taken up for the highest lift. Any ideas?
Not sure what size deck is on your other tractor but i can tell you that the spindles in a 48" deck are about an inch longer than a 38 or 42" deck. If your other tractor has a smaller deck it will automatically have another inch of lift just because of the shorter spindles.
The 123 has a 42in mower and in 'transport' position the blades are about 6in off the floor. The 127 has a 48in mower and only clears 3.5in. Measuring things today I came to the same conclusion, the deck is deeper and spindles longer.
Thread Tools | |
Display Modes | |
