Greg Rozar AKA- CubDieselFan
Old 06-23-2014, 09:40 PM
kring kring is offline
Originally Posted by DoubleO7 View Post
If the sleeve hitch adapter is "floating" how is any trailer weight on the tractor?
there isnt... that was why i added the wheels so i would just be pulling the weight and not carrying any of it. I tried it without the wheels, it sheered the pins in the lift lever the first bump i went over.
maybe "floating" isnt the proper term....i was referring to the fact the lifting straps on the sleeve hitch itself are slotted, allowing the hitch with the wheels to move up or down if need with the couture of the ground. I would assume if it didnt, you'd get high centered and lose traction every time you went through a pothole.
c69ss396 - excellent idea...If the wheels i have on there dont hold up, I'll get some like those
127
129
1650
Old 07-05-2014, 09:24 PM
Mr.Goffena's Avatar
Mr.Goffena Mr.Goffena is offline
By the looks of the gravel pin in the back ground you are alot closer to me than I thought. Nice tractor BTW.
107 with rear lift
1250 hyd lift. 682 diesel project
Original project
#2 and tiller
#2 trailer
59M sheader
home made boxblade
wideframe 54" snowplow
Old 07-23-2014, 10:00 PM
Soloboss Soloboss is offline
As I poke around here I'm thinking you guys are BRILLIANT! SO much cool stuff.
Mark
2001 Cub 2206, 2014 Ariens Compact 24 Sno Thro, 1969 Ariens Compact 20" 5hp Tecumseh Sno Thro, 1998 Lawn Boy Gold Pro mower, Troy Bilt Tomahawk chipper/shredder, Generac 5500 watt Generator, Generac 2300 psi Power Washer, 2003 Honda ST1300a motorcycle and the 1971 Triumph Spitfire that I bought new.
