Greg Rozar AKA- CubDieselFan
Old 12-10-2017, 09:42 AM
Vrobert's Avatar
Vrobert Vrobert is offline
Default bought a 1/2" IR impact
You guys like tractors and tools so you might be interested in this sale. I haven't used this yet but I'll report back. Seems like a pretty good price. Years ago when I got my first compressor I bought a cheap 1/2 impact gun but when you have a real tractor I guess you need real tools.
https://www.tractorsupply.com/tsc/pr...+Impact+Wrench
Rusty 149 project with:
QA42 snow thrower
38" deck
Barn fresh 1811 with:
44c mowing deck
QA42A snow thrower
42" snow blade
Old 12-15-2017, 01:32 AM
Steve N Mi Steve N Mi is offline
Default Snow detail
Cleared my drive and a good deal of my yard of 7+ inches of the white stuff. I had so much fun with the 1872 and 54" power angle blade that it was hard to stop. I have a 54" RAD 2 stage blower/thrower outfitted for an 1872 but it would have been all over tooo quickly plus it wasn't mounted on a tractor - maybe next time.
Old 12-16-2017, 07:37 PM
akerim01 akerim01 is offline
Default 451 on an 1862
Im sure this has been talked bout numerous times but I have an 1862 and purchased a 451 snowblower. Its an early serial numbered tractor and i need an answer on changing the PTO out for the bigger pulley. Im hearing dont worry about it. Im hearing you have to change it. Any help is appreciated. Thanks in advance!
Old 12-16-2017, 07:58 PM
Post this question in this area Implements and Attachments
Old 12-18-2017, 12:48 PM
89cubcadet1772's Avatar
89cubcadet1772 89cubcadet1772 is offline
First work out for the 1772 this winter, little clip of clearing out the drainage area behind house.
https://www.youtube.com/watch?v=_wg0N0LfTGo
89' Cub Cadet 1772
Old 12-18-2017, 12:52 PM
That will get the job done!
Old 12-18-2017, 01:00 PM
Heck ya, nice action shot of the smoker!
Old 12-18-2017, 10:25 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Very Nice!! Looks like the old girl was doing a good job!!
Jay
Proud owner of the following:
Old 01-23-2018, 06:32 AM
Cannon51's Avatar
Cannon51 Cannon51 is offline
The box rebuild and new steering joints got almost all the slop out of the 1641 steering. I've been using it to pull a cart the last few weeks and there is a tight place with the wheel 90 degrees from from center on both sides. I didn't know what I was doing when took the box out, I took the bottom part of the upper CV joint part and didn't make an index mark. When I was putting everything back together I had a hard time moving the CV joint around to line it up with the box. When I got the upper shaft and joint out yesterday I found it was tight at one place, when I loosened the bolts it freed up. I plan on taking it apart today and see if I can get it working right. Hopefully I won't mess anything up in the process.
Cannon
Old 01-25-2018, 12:42 PM
Cannon51's Avatar
As a last resort I checked the service manual section on the upper steering and today got it back together and in the 1641. I drove it around and the tight place is gone. The steering joints I used have some of the grease fittings aimed toward the frame so I ordered this. https://www.amazon.com/Lincoln-Lubri...grease+coupler It's a little aggravating to use but it does work.
Cannon
