Greg Rozar AKA- CubDieselFan
Old 10-23-2017, 12:42 PM
jimbob200521's Avatar
Default Anyone make a rear 2" receiver that will fit on the existing plate?
I know that eXtreme makes a rear 2" receiver that bolts to both the cast and aluminum rears but what I'm looking for is one that will bolt to the rear cover plate that the Cyclops have. I see they have one with a description of "This one fits the Category 0 - 3 Points above. Lower clearance on the mounting plate keeps it from hanging too far below the 3 point plate.". I'm thinking this is the one I want but want to make sure before I hit the buy button (going to have a hitch style salt spreader, for those curious minds). Pic below is of my Super but same style rear plate. Please tell me I'm making this more complicated than it needs to be, something I hear every now and then in life
-Ryan
Old 10-23-2017, 01:11 PM
You're making this more complicated than it needs to be.
Old 10-23-2017, 02:36 PM
What he said
Old 10-23-2017, 10:23 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Yep, what they said... ^^^^^^^^^^
1- 1200 in pieces
1- 1864 in pieces
Old 10-24-2017, 07:44 AM
drcjv's Avatar
drcjv drcjv is offline
Harbor freight has a receiver for an ATV that bolts to your draw bar and cost about twelve bucks. I have them on all my supers. Not sure if it would work for you. I use with ball to move trailers and such around.
Charles________________________
1572 3pnt, rear PTO, 50" deck
1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow
1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow
2072 3pnt 50" deck, Brinly Plow
2072 50" deck
Cub Cadet Tank 50 Zero Turn
Cub Cadet 33" Commercial Walk Behind
1953 Ih Cub with just about every implement
New Holland TC33D with Loader and Backhoe
Old 10-24-2017, 08:02 AM
Is this it Charles?
https://www.harborfreight.com/atv-hi...ter-65961.html
Old 10-24-2017, 09:26 AM
drcjv's Avatar
Oak that's it and as I said it works great with a ball.
2072 50" deck
Old 10-24-2017, 10:42 AM
While not what I was thinking, that would be perfect! I just want to attach a hitch style salt spreader to it and that may be the easiest way to get the job done. Shouldn't need to hold more thank a couple hundred pounds at worst.
-Ryan
Old 10-24-2017, 02:45 PM
sorner's Avatar
sorner sorner is offline
You're making this more complicated than it needs to be... Why put a 2" receiver and all that on it when you can just get a 5/8" (i think that's the size) shaft ball and drop it right in the hole and snug it up? That's all I have and it works great for moving my trailer with a 2" ball around and other stuff. If I need to take it off to use something with a pin, i just take it off.
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower
IH Cub Original with deck
#2 cart
GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck
Old 10-24-2017, 03:01 PM
My guess is that Ryan wants to use a spreader something like this one.
I would get a piece of steel plate, use the existing hitch as a template to drill the 5 bolt holes then weld a receiver tube to it. You can get a receiver tube at any decent RV supply store or from Northern Tool.
Thread Tools
Display Modes
