#81
I took my delivery valves apart and cleaned everything good and put it back together. I don't have fuel shooting all over now. So I made a quick video on how I checked the injector timing. This is the only way I could find on how it's done. Let me know if it looks right
http://youtu.be/BjuAz4SjGsY
1450 w/ 44gt deck, 1572 w/ 50C deck, 450 snowblower. |
#82
Timing looks good to me. How did you clean the delivery valve? |
#83
I unscrewed the top where the injector line hooks and removed the spring and delivery valve. I cleaned everything with WD-40 and reassembled. I needed to get the fuel to stop squirting all over so I could check the injector timing. I'm still going to call and see about getting the pump tested.
I noticed if you unscrew the torx screws each delivery valve can be adjusted by rotating it. The holes are slotted. I assume this can adjust fuel to each injector. I think this is set during the rebuild process. I used to be an ASE certified mechanic at a Chevorlet dealer until I realized I didn't want to turn wrenches for a living. I just never had much opportunity to work on diesels. I can figure most things out but I do appreciate the help from people that know more about these diesels than I do.
#84
did we find out if it is fixed yet whats goin on
982D kwik-way loader w/3 spool control and front and rear remotes,2182, 1812 cat 0, 1440 puller, 3185 grass killer, 2x 450s, QA42, 364, tiller |
#86
Injection pump was bad. I should be getting it back this afternoon. I took it in for a rebuild Monday.
#87
keep us posted
#88
#89
I was originally supposed to get the injector pump back Friday but they didn't have it done. Got it today and hammered it together so I could get my driveway back. It started 100% better than it used too. It also seems to idle smoother and put out less smoke. Not sure what they did but I can tell you it was just shy of $500. Seems a bit steep but it works and I don't expect to have to mess with it again.
#90
Glad you got it fixed. Enjoy
3 original cubs 1512 diesel Ingersoll 3012 John deere 855 |
