You should have painted the letters first in black,the fill them with with honey,then painted the yellow.Then eat the honey.
Candle wax would work also.Heat it up to get the wax off the black paint.
I was thinking some form of black liquid epoxy that has a cure/setting time of at least several hours. Draw a bead of epoxy in center of valleys and the stuff would eventually flow out to the edges.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
the honey would sure taste better than the wax!
red 162 heavily weighted w/electric lift 23*stones and tri ribs(workhorse), 1250 weighted 23*stones and v61's(tiller tractor), 108 w/44" mower awaiting some work, 800 voted worst shape awaiting restoration, and a few random "other" branded tractors |
Are those cover made of some kind of plastic? I remember a product I use once it was a green liquid stuff you can spray with a airbrush, I think the name was "Liquid mask". You just cut carefully and remove with an xacto the surface you want to paint, wen it's done that stuff can be peeled away like a banana skin.
Gilles. 1988 2072 401 54" hyd angled blade 1988 1872 364 snowblower/C50 deck 1976 1650/QA42A blower/44A deck/standby 1976 1450TS/Sleeve hitch/44A deck/in storage 1963 100 (red)/in storage 2010 Kubota 2380-2/42" infinity deck (engine swap) |
