Greg Rozar AKA- CubDieselFan
Old 05-14-2017, 10:57 AM
Here's the clutch.
Old 05-17-2017, 07:00 PM
Alright guys it's up and running under its own power but there's an issue, clutch isn't disengaging to put it into gear, plates and disc keep spinning, but if I try anyway to put it into gear it will pop in with almost no grinding then they stop turning, any ideas?
Old 05-17-2017, 08:05 PM
The Kevlar clutch in my 108 did that till I got some hours on it. How much free travel do you have?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 05-18-2017, 06:34 AM
It seems to have enough free play, I adjusted it and now the plates and shaft just about stop, but disc still spins, shifts into gear without grinding, I'll check it later and report back, seemed like it slipped alittle too, but I have since adjusted it.
Old 05-18-2017, 07:38 AM
It's not about having enough free travel it's about having to much. More free travel means less movement on the throw out bearing when you push the pedal down which means less release on the clutch, this might be where your problem is. I've never checked the manual to see how much free travel they recommend but adjusting a clutch isn't exactly rocket science, as long as you have enough free travel to keep the arm from riding on the bearing you should be good. I set mine to between an 1/8" and 1/4" of free travel.
If the clutch isn't fully releasing like you say I highly doubt it's slipping unless you have the shaft assembled wrong, I would adjust the free travel and take it for a spin.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 05-18-2017, 07:59 AM
Thanks for the help, i'll check it out later and post back, it seemed better last night after i adjusted it after thinking it was slipping so hopefully its fine, at first it seemed like too much free travel, disc still turns but the rest seems good, shaft looks assembled correctly.
Old 05-18-2017, 09:53 AM
I will be dead sled pulling, I will have plenty of counter weight on it, as well as wheelie bars.
Nick, if the hitch is too high, and you roll back on the wheelie bars, you will lose traction and spin out. The wheelie bars are just so the tractor doesn't tip over. If the wheelie tires are rolling all the time, you're rolling back too far.
It doesn't matter what kind of sled it is, application is the same.
This is why I don't comment on your threads much. You don't listen.
Old 05-18-2017, 10:07 AM
Good, just the way i like it. thanks for the advice, I stated I won't be using it.
Old 05-18-2017, 07:21 PM
Nearing completion, I think it looks awesome!
Old 05-18-2017, 08:19 PM
So does the clutch work?
Pap's 100
Restored 108
1211 Dual Stick
1050
