LT 1554 repower sugguestions
So the neighbor guy has a lt1554 that the motor is blown. He says it ain't worth fixing and I can have it. Any ideas for a replacement motor for it? Keep in mind that I am trying to do this as cheaply as possible. Also can anyone tell me the diameter and length of the output shaft on the motor? I am more into the IH cubs, these newer mtd ones are foreign to me so if I sound stupid I apologize in advance. Thanks in advance for any advice.
-Bob- 149 w/48"deck, 2 100s and and 2 ugly "O"s parts 104 |
That mower should have the Kohler 27hp v twin, correct? I just changed out the same type motor in my zero turn with a Briggs v twin that I lucked up and got for about $600 instead of a grand. Now with that said, I have found several Briggs V twins on Craigslist for $300 and under, I just simply wanted a new motor that I would not have to worry about. The main shaft should be @ 3 1/8" in length. I will have to check on the diameter. I want to say 1" but may be 3/4". The wiring really turned out to be pretty easy once I got my head wrapped around what the colors for the factory wire harness did and what needed to be connected to the engine. I also had to add a starter selonoid as the Briggs does not have that built into the starter like the Kohler does. Also another plus is that the exhaust pipes from the Kohler mounted up perfectly to the Briggs, so there should be no surprises there. Other than that it's not bad. I did have to study the wiring harness diagram a bit, but I think I can get some pics of how I have mine wired up for you to see how it should work.
Here are the correct specs and style of motor.
http://www.ebay.com/itm/BRIGGS-STRAT...item2ed8d31072
Cool thank you I will have to see what I'm going to do
